Could I? Should I?
10 inch Terror
Xbox live gamer tag: No.
Hi all, I have the older type LI150 gearbox, with the hole through the Xmas tree. With it, I have the matching LI clutch pressure plate with the spline that guides it into the Xmas tree. Now obviously it has the nipple on it. Could I, should I grind that off to enable me to use a GP side casing? I like the idea of the guide helping keep everything central. Any advice gratefully received.
eden
Buy an LI sidecase
10 inch Terror wrote:Hi all, I have the older type LI150 gearbox, with the hole through the Xmas tree. With it, I have the matching LI clutch pressure plate with the spline that guides it into the Xmas tree. Now obviously it has the nipple on it. Could I, should I grind that off to enable me to use a GP side casing? I like the idea of the guide helping keep everything central. Any advice gratefully received.
Yes....i do it on the Winco pressure plates all the time.
10 inch Terror
Cheers drunkmunkey.
