Could I? Should I?
10 inch Terror
Xbox live gamer tag: No.
Hi all, I have the older type LI150 gearbox, with the hole through the Xmas tree. With it, I have the matching LI clutch pressure plate with the spline that guides it into the Xmas tree. Now obviously it has the nipple on it. Could I, should I grind that off to enable me to use a GP side casing? I like the idea of the guide helping keep everything central. Any advice gratefully received.
eden
Buy an LI sidecase
10 inch Terror wrote:Hi all, I have the older type LI150 gearbox, with the hole through the Xmas tree. With it, I have the matching LI clutch pressure plate with the spline that guides it into the Xmas tree. Now obviously it has the nipple on it. Could I, should I grind that off to enable me to use a GP side casing? I like the idea of the guide helping keep everything central. Any advice gratefully received.
Yes....i do it on the Winco pressure plates all the time.
10 inch Terror
Cheers drunkmunkey.
    Users browsing this forum: Baidu [Spider] and 4 guests
