Could I? Should I?
10 inch Terror
- Xbox live gamer tag: No.
- Playstation gamer tag: PLEASE!
- Main scooter: Lambretta LI Imola 185
Hi all, I have the older type LI150 gearbox, with the hole through the Xmas tree. With it, I have the matching LI clutch pressure plate with the spline that guides it into the Xmas tree. Now obviously it has the nipple on it. Could I, should I grind that off to enable me to use a GP side casing? I like the idea of the guide helping keep everything central. Any advice gratefully received.
Buy an LI sidecase
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
Yes....i do it on the Winco pressure plates all the time.10 inch Terror wrote:Hi all, I have the older type LI150 gearbox, with the hole through the Xmas tree. With it, I have the matching LI clutch pressure plate with the spline that guides it into the Xmas tree. Now obviously it has the nipple on it. Could I, should I grind that off to enable me to use a GP side casing? I like the idea of the guide helping keep everything central. Any advice gratefully received.
10 inch Terror
Cheers drunkmunkey.drunkmunkey6969 wrote:Yes....i do it on the Winco pressure plates all the time.10 inch Terror wrote:Hi all, I have the older type LI150 gearbox, with the hole through the Xmas tree. With it, I have the matching LI clutch pressure plate with the spline that guides it into the Xmas tree. Now obviously it has the nipple on it. Could I, should I grind that off to enable me to use a GP side casing? I like the idea of the guide helping keep everything central. Any advice gratefully received.
- Information
Who is online
