Damn & Blast !!!! again
mickymidas
Main scooter: Vespa Rally /P200
Happened again !!!
Flywheel side bearing race working its way off crank & pushing through seal , leaving bearing on the p#$$. Any ideas of the cause & how to rectify the problem ?
HB stage 4 P200 kit , HB fettled crank , B8es plug , 4% oil .
2Ronnies sc.......Chuckleism is the way forward
eden
New crank with a less worn race seating.
mickymidas
Cheers pal , think I had already made my mind up a new crank was needed , but needed a nudge in that direction :)
wack 63
Main scooter: '71 GP TS1
Depending on how worn the crank is where the bearing sits, you may get away with some bearing retainer.
Ginch
Main scooter: Vespa 150 Super
And if the crank is buggered anyway, you could try a fairly liquid high temp epoxy to glue it into position.
fastfrog
Got the very same issue on my tameni T5 crank. Race was easy to fit on the crank shaft. Usually it needs a certain amount of strength to shove it down. Crank and bearing were brand new and I tried another bearing just to see and it the very same prob. Shaft was a bit to narrow. I glued the whole thing with a big amount of Loctite 648 and it never happened again....
Size matters!
oldbiker
there are bearing grades of loctite, but i`d be tempted to go for a new crank and bearing
