Happened again !!!
Flywheel side bearing race working its way off crank & pushing through seal , leaving bearing on the p#$$. Any ideas of the cause & how to rectify the problem ?
HB stage 4 P200 kit , HB fettled crank , B8es plug , 4% oil .
Damn & Blast !!!! again
mickymidas
- Main scooter: Vespa Rally /P200
2Ronnies sc.......Chuckleism is the way forward
New crank with a less worn race seating.
mickymidas
Cheers pal , think I had already made my mind up a new crank was needed , but needed a nudge in that direction
- fastfrog
- Main scooter: T5 mk1, SS180, PX200 millenium
Got the very same issue on my tameni T5 crank. Race was easy to fit on the crank shaft. Usually it needs a certain amount of strength to shove it down. Crank and bearing were brand new and I tried another bearing just to see and it the very same prob. Shaft was a bit to narrow. I glued the whole thing with a big amount of Loctite 648 and it never happened again....
Size matters!
there are bearing grades of loctite, but i`d be tempted to go for a new crank and bearing
It`s all powerfull white mans magic
My Scoots,
http://i897.photobucket.com/albums/ac17 ... CF0600.jpg
http://i897.photobucket.com/albums/ac17 ... 01/035.jpg
My Scoots,
