Best plates n springs
wack 63
Main scooter: '71 GP TS1
Using a PX/T5 7 spring clutch ,which clutch plates and springs would be a good choice for a Pinasco 225?
johnny rotten
Main scooter: px200e
Just used to use std plates n malossi springs on my old malossi 210 worked fine
wack 63
I agree ,used them in the past on Malossis' just wondered if anything newer/better
johnny rotten
Harry Barlow uses them on his tuned engines so its got a proven track record sorry can't suggest anything else
wack 63
Ok thanks
roadrunnerian
i find malossi springs a bit stiff i use pinasco springs with a standard clutch on my t5 171 m8
Juan
Not keen on Malossi springs myself, or at least not the whole lot. I'd use 4 Malossi and 3 standards if you can't get the DR ones. Not tried the Pinasco ones but they could be worth a try. Standard 3 plate is fine.
goldeneye
3 plate , DR springs and a SIP spacer washer underneath the clutch is what I run ,no problems.
GLscoot
Main scooter: Vespa GS150
I've not used them but DRT and BGM are making clutches for the Vespa, but they are expensive.
gimp1971
Main scooter: vespa t5
I bought some mallossi ones for my t5 but Diablo used some other ones as he said they are to stiff i will see him later so will ask
