Best plates n springs
johnny rotten
- Main scooter: px200e
Just used to use std plates n malossi springs on my old malossi 210 worked fine
johnny rotten
Harry Barlow uses them on his tuned engines so its got a proven track record sorry can't suggest anything else
roadrunnerian
i find malossi springs a bit stiff i use pinasco springs with a standard clutch on my t5 171 m8
Not keen on Malossi springs myself, or at least not the whole lot. I'd use 4 Malossi and 3 standards if you can't get the DR ones. Not tried the Pinasco ones but they could be worth a try. Standard 3 plate is fine.
3 plate , DR springs and a SIP spacer washer underneath the clutch is what I run ,no problems.
