SIL GP legshields
mickdale
are SIL gp legshields exactly the same as italian ones?
cheers
mick
mickdale wrote:are SIL gp legshields exactly the same as italian ones?
cheers
mick
Same fitment but sometimes different in shape
and some times not even symmetrical :flaming:
mickdale
ive got some legshileds and with the outer plastic runners fitted, the sharksteeth sit in "fresh air" - and the folded down sides are an inch or two shorter
definitly gp ones but why would theymake them like that???????????
nervous about buying sil gp ones in case they dont fit italian frame
I think the Fitment maybe down to the maintenance of the tooling recieved from innocenti causing mishaping and contour issues :cry:
mickdale
they cant be from the same presses - the sharks teeth area is in completely the wrong position in relation to the rest of the leggies
will have to try the side runners on some leggies before purchase to confirm they are ok - i just cant understand why they were made so far out - the pressing is otherwise good
mickdale wrote:they cant be from the same presses
they will be .. but just think how many they will have pressed by now .. worn out i would say
^agreed^ speaking from experience of the Aircraft industry tooling :cry:
mickdale
mickdale
