are SIL gp legshields exactly the same as italian ones?
cheers
mick
SIL GP legshields
- Toddy
- registered user
- Main scooter: Lambretta Series 1
- Contact:
Same fitment but sometimes different in shapemickdale wrote:are SIL gp legshields exactly the same as italian ones?
cheers
mick
ive got some legshileds and with the outer plastic runners fitted, the sharksteeth sit in "fresh air" - and the folded down sides are an inch or two shorter
definitly gp ones but why would theymake them like that???????????
nervous about buying sil gp ones in case they dont fit italian frame
- Toddy
- registered user
- Contact:
I think the Fitment maybe down to the maintenance of the tooling recieved from innocenti causing mishaping and contour issues
they cant be from the same presses - the sharks teeth area is in completely the wrong position in relation to the rest of the leggies
will have to try the side runners on some leggies before purchase to confirm they are ok - i just cant understand why they were made so far out - the pressing is otherwise good
they will be .. but just think how many they will have pressed by now .. worn out i would saymickdale wrote:they cant be from the same presses
- Toddy
- registered user
- Contact:
^agreed^ speaking from experience of the Aircraft industry toolingRICSPEED wrote:they will be .. but just think how many they will have pressed by now .. worn out i would saymickdale wrote:they cant be from the same presses
