Rat-Racer - not a Rat Racer any more - new Projekt 03/2011
t5pien
Main scooter: PX 221, SKR 172
hello
this is my ride
PX-200 Engine Case
Malossi 210 and Piston - completly ported 196,5 / 135
Polini Piston bolt ( lighter )
S & S Longstroke Crank 60 mm
S & S Reed-Intake
RD-350 Membran
Boysen Plates
Vespatronic - Ignition
MMW - Flywheel form verspatronic Igotion
S & S - Exhaust
MMW CNC Clusch 8 xl, 8xxl springs
130 / 70 / 10 on real 4 inch - s & s kit
35 Mikuni carb - HD 300, ND 15, 53´er Nadel 1. Clip
Zylinderhead - low compression 1:10,5, QK 1,5-1,7
Primär: 23/65
gearing: Lusso 200
4 th gear - T5 short
3 rd gear DRT - extralong
Mikuni- fue lpump 14 l
T5 Rearbrake
more than: 35 hp
topspeed: never tested more than 143 - nearly 150
hardcore acceleration
--> daily driver
front and backcut
bitubo´s
dropbar,
blue H4-Lights
back and flashlights LED
grimca disc-brake
paintjob: :mrgreen:
everything made by me, except welding
everything with TÜV - that means you can drive this scooter legal on german streets
more pictures here
http://www.germanscooterforum.de/Galeri ... 88316.html
the hole story ( about 1000 pictures of building ) - sorry complete german
http://www.germanscooterforum.de/Vespa_ ... 82430.html
short youtube videos - still with the first after 1000 mile broken engine ( nearly everything was broken )
http://www.youtube.com/watch?v=TIn4Ky8j ... r_embedded
http://www.youtube.com/watch?v=4IwYfZuq ... re=related
LI150
Main scooter: Series 2 LI150
Cool like this Bet it that takes some holding onto when flat out. Have you strengthened your cases as noticed that from build the ones in pics are different take it first ones didnt last
Diablo
Cool a lot of hard work there. Does it pull the gearing with such long exhuast timing? Thats pretty tall with the extra gearing from the tyre.
The crank is interesting-is that off the shelf at S&S?
t5pien
Diablo wrote:Cool a lot of hard work there. Does it pull the gearing with such long exhuast timing? Thats pretty tall with the extra gearing from the tyre.
yes it was "hard work" except the custom paintjob :mrgreen: ( brush ) , but i work in an office and i need the garagework to keep my head clean ( i hope you understand what i mean ) - working the hole day with a computer sucks - building bikes in the evening rule.
the whole scooter took about 3 month - Jan 2 2010 - märz 30 2010 - ( only in the evenings after work and sometimes the whole weekend ) inkl. the old engine.
bulding the compete new engine after the complete crash in april took about 5 day´s. this winter the scooter gets a fine paintjob, a little bit more power, a new exhaust. this scooter is never ready - i´m still some changing parts .. it´s a daily driver
gearing:
it´s really no problem - the new extra long third gear from drt ( one tooth less ) and the short gear from the t5 works exellent together. the scooter is much lighter than a original px - my weight is about 80 kilogramms - maybe heavier persons have problems with this enginesetup
tyre - and gearing:
i don´t think the amount of the backwheel is much more than a normal 3,5 tyre
here i made a little topic in the german scooteroforum about this kit
http://www.germanscooterforum.de/findpo ... 15584.html
this shop offers the kit
https://shop.strato.de/epages/61438057. ... cts/SS1111
this is my crank:
santacama
Thanks for so much info .... way to go.
Nice
C*NTSPEED
loving thi crank
GEMINI S.C.
BLACK WIDDA'S S.C.
t5pien
i made a little misstake - i wanted more power ( 2 weeks ago ): after porting the cylinder nearly 140/196 driving trough town sucks. the carb-setting wasn´t good at all - i lost about 4-6 hp
look here - germany rotenburg 3. oktober 2010 - dragracing :
my run - at 0:41 seconds:
http://www.youtube.com/watch?v=yfaoJ75v ... r_embedded#
now down on 134/195 - the power came back, but not as good as before, i need a new cylinder - carbsetting now: 35 mikuni with 57 needle 2. clip, mainjet 290, "other jet" 17,5 - the engine runs now till 9600 upm and have about 36 hp with a better bandwitch than you see above - a new dynorun will be posted in a few days
i think best timings for this machine is 131/195
t5pien
hello,
i ´m buidling a complete new one - only a few parts from the old one come into the new racer. every screw, rubber etc. is new. no rat-racer this time, i want a clean, smart and really fast cutdownracer. last time a had about 32-36 hp ( depends on the timing ) - this time i hope to get the 40 hp
the hole story ( german ) hundreds of pics http://www.germanscooterforum.de/Vespa_ ... 07605.html
80 photos from the last few weeks :
http://s811.photobucket.com/albums/zz34/t5pien/Pi%202/
changes
engine - more power :
- complete drt-gearbox
- new reed intake with boyesen reeds
- all bearings, clutchplates screws etc new
complete setup
PX-200 Engine Case
new Reed intake
RD-350 Membran
Boysen reeds
S & S - Exhaust
Primär: 23/65
T5 Rearbrake
- shortend fork( 5 cm ) with new bitubos
- new digital speedo
- new chassie
- ... too much to list
i hope i finsh the project to the easterrun in hamburg
    Users browsing this forum: No registered users and 54 guests
