CHT readings?
eden
have you tried putting the sensor in boiling water to see how fast it rises and if it reaches 100C?
Fux
Main scooter: li150 S2
Nope, good point. Think I`ll try the one i have taken off first to see which one is dodgy.
Bufficus
Westach gauge under the plug sensor.
Tuned TS1 with Ron Moss head.
100-150 Celcius.
dansacred
Main scooter: li 150 series 3
tuned ts1, clubman, pwk30 150-160 have seen 180c though
Fux
My SIP sensor under plug, 155 celcius at full whack over a longer perioud.
Around 135 cruising.
Rick
Main scooter: Jet200
On top of the plug between 170-180F running an Avanti
Rick wrote:On top of the plug between 170-180F running an Avanti
what sensor do you have i have the sip speedo and it reads about 185 but from cold the sensor reading is alreadt 130 :shock:
Tractorman
What is the consensus on the seize point.
When the piston expands to the point it has no clearance on the barrel.
Don't think you'll be able to quote a precise figure on that as it will be different on different engines.
Rick
Mines sip as well but it will drop to the air temp near enough when cold
