CHT readings?
eden
have you tried putting the sensor in boiling water to see how fast it rises and if it reaches 100C?
Fux
Main scooter: li150 S2
Nope, good point. Think I`ll try the one i have taken off first to see which one is dodgy.
Bufficus
Westach gauge under the plug sensor.
Tuned TS1 with Ron Moss head.
100-150 Celcius.
dansacred
Main scooter: li 150 series 3
tuned ts1, clubman, pwk30 150-160 have seen 180c though
Fux
My SIP sensor under plug, 155 celcius at full whack over a longer perioud.
Around 135 cruising.
Rick
Main scooter: Jet200
On top of the plug between 170-180F running an Avanti
Rick wrote:On top of the plug between 170-180F running an Avanti
what sensor do you have i have the sip speedo and it reads about 185 but from cold the sensor reading is alreadt 130 :shock:
Tractorman
Main scooter: Lambretta li150 special
What is the consensus on the seize point.
When the piston expands to the point it has no clearance on the barrel.
Don't think you'll be able to quote a precise figure on that as it will be different on different engines.
Rick
Mines sip as well but it will drop to the air temp near enough when cold
