CHT readings?
have you tried putting the sensor in boiling water to see how fast it rises and if it reaches 100C?
what sensor do you have i have the sip speedo and it reads about 185 but from cold the sensor reading is alreadt 130Rick wrote:On top of the plug between 170-180F running an Avanti
Tractorman
- Main scooter: Lambretta li150 special
What is the consensus on the seize point.
When the piston expands to the point it has no clearance on the barrel.
Don't think you'll be able to quote a precise figure on that as it will be different on different engines.
Rick
- Main scooter: Jet200
Mines sip as well but it will drop to the air temp near enough when coldshocky wrote:what sensor do you have i have the sip speedo and it reads about 185 but from cold the sensor reading is alreadt 130Rick wrote:On top of the plug between 170-180F running an Avanti
