Inlet Manifold Gasket?
bazza3004
Always used inlet gaskets with sealent for belt n braces etc. Dont bother with exhaust gaskets as thats the usual thing to go on exhausts. I just make sure both faces are flat and use a decent sealent. Expect you could do the same with inlet.
Grumpy225
hendy wrote: Mon Aug 28, 2017 10:00 pm
Grumpy225 wrote: Mon Aug 28, 2017 8:38 pm
If you are using a cereal box then I look forward to reading how you motor has developed a mysterious air leak and you melted a hole in your piston. Good luck.
I completely agree, and that is why I said to use a nachos box.
:mrgreen:
Nachos out of a box? That's down right criminal. What's next, cheese in a can?
bristolmod
Martin20 wrote: Mon Aug 28, 2017 5:05 pm Evening All,
Planning to try a 22mm carb on my LIS150 in the not too distant future. Question is, do I need to fit an inlet manifold gasket, or can I get away with using gasket sealant? Also, if a gasket is recommended, is it OK to buy gasket paper and make my own? Sorry if it sounds a dumb question, but I have done loads of reading, and nowhere have I seen it give a definite yes or no!
Cheers
Martin
Gaskets are cheap and easy to come by. I literally have 100's of extras from various builds. Every gasket set comes with at least 1 intake and they are only used about 1/4 of the time in rebuilds (seal/bearing jobs).
If you are changing your manifold then replace the gasket (use gasket sealer). If you are using a cereal box then I look forward to reading how you motor has developed a mysterious air leak and you melted a hole in your piston. Good luck.
used cereal boxes for 49 years- no problems- at least they fit.
Scootering since 1968.
hendy
Grumpy225 wrote: Mon Aug 28, 2017 11:23 pm
:mrgreen:
Chicken in a can. Seriously. Google it.
