Inlet Manifold Gasket?
Martin20
Main scooter: Lambretta LI 150 Special
Evening All,
Planning to try a 22mm carb on my LIS150 in the not too distant future. Question is, do I need to fit an inlet manifold gasket, or can I get away with using gasket sealant? Also, if a gasket is recommended, is it OK to buy gasket paper and make my own? Sorry if it sounds a dumb question, but I have done loads of reading, and nowhere have I seen it give a definite yes or no!
Martin
Scoot
Main scooter: Lambretta Jet200
Gasket sealant is fine
Sent from my iPhone using Tapatalk Pro
bristolmod
use a cereal box- grease up the end of the inlet manifold and press down. Cut round the ungreased areas.
Chris
Scootering since 1968.
hendy
bristolmod wrote: ↑Mon Aug 28, 2017 5:51 pm use a cereal box- grease up the end of the inlet manifold and press down. Cut round the ungreased areas.
Chris
Bad advice.
Use an "old el paso" nachos kit box; cereal boxes aren't Tuv approved.
mick1
Main scooter: Li Avanti 225
Is there a reason for not wanting to buy a ready made gasket ?
Sealants fine but I use sealant and a gasket.......belt and braces and all that.....
hendy
mick1 wrote: ↑Mon Aug 28, 2017 6:47 pm Is there a reason for not wanting to buy a ready made gasket ?
I found that gaskets didn't cover the gasket face properly so made my own.
Martin20
No, no reason. Just doesn't seem to be that many for sale, so wondered if they were really necessary!
Thanks for all replies guys. Think I will try a cereal packet gasket (cornflakes or weetabix, hmmm) with sealant.
I seem to remember that my genuine LI150S barrel has the same shape (round) and size inlet gasket as a TV175, which is different to the other L150s, so you might want to make your own anyway. I too would rather use a gasket than just sealant but a bit 'horse for courses'.
Adam
Grumpy225
Martin20 wrote: ↑Mon Aug 28, 2017 5:05 pm Evening All,
Martin
Gaskets are cheap and easy to come by. I literally have 100's of extras from various builds. Every gasket set comes with at least 1 intake and they are only used about 1/4 of the time in rebuilds (seal/bearing jobs).
If you are changing your manifold then replace the gasket (use gasket sealer). If you are using a cereal box then I look forward to reading how you motor has developed a mysterious air leak and you melted a hole in your piston. Good luck.
hendy
Grumpy225 wrote: ↑Mon Aug 28, 2017 8:38 pm
I completely agree, and that is why I said to use a nachos box.
