Spluttered. Won't rev
mick1
Main scooter: Li Avanti 225
fuel cap breather hole ? try without cap on (not with a full tank!!)
biddy
check pilot jet hasn't come lose ,had the same problem done everything but check carb
vRSG60
Main scooter: Lambretta Li125 Lambretta GP20
Same thing happened to mine.
Started 1st kick but wouldn't run or rev more than 2 seconds. Changed plug same again, changed plug same again etc.........
Changed CDI unit everything worked fine.
I get my kicks out on the floor.
Bilko
Main scooter: LI150
Flywheel hasn't moved from the woodruff key.
Ignition is ok (took green from loom out of the CDI).
I'm hoping it's carb related. Just stripping it now to clean. Hasn't been cleaned in a long long time. So here's hoping. :/
Bilko's Oily Blog
Bilko
Main scooter: LI150
Changed everythng. Carb, CDI, plugs etc. Wants to start but if it does it's only for a couple of seconds.
Bilko's Oily Blog
vRSG60
Well it can only be 1 of 3 things -
Air
Fuel
Electrical
Bilko
Main scooter: LI150
Stator readings from multimeter are within the range according to Sticky's manual.
Bilko's Oily Blog
goldeneye
fuel tap is fooked,thats my guess.
Bilko
Main scooter: LI150
Fuel tap working correctly - Just checked flow.
Bilko's Oily Blog
johnd
Main scooter: 1970 Dl125
Sticking float.
    Users browsing this forum: Amazon [Bot], Semrush [Bot] and 7 guests
