Spluttered. Won't rev
Bilko
Main scooter: LI150
Went to go out last night and after a the usual first/second kick start and clean revs, I got a hundred yards and it started to splutter and wouldn't rev and then died.
There's a good spark and it tries to fire up and if it does it just dies after an attempt to rev it.
It was a bit smokey and the plug is wet, but really oily.
Bilko's Oily Blog
Muppet
flyweel spun on taper
C’est la vie
Bilko
Main scooter: LI150
Thanks I'll have a look
Bilko's Oily Blog
Bilko wrote:Thanks I'll have a look
Check that the choke isn't stuck on first ;) Just had something very similar on mine :oops:
Donnie
It's in Norn Iron! I'll give ya 50 euro an oim slittin me own froat govner!! :-)
Donnie.
Bilko
Main scooter: LI150
I use one of Darrell's chokes Colin, but I have checked. It started perfectly and ran perfect til I got 100 yards down the road.
Bilko's Oily Blog
Timbo
Stator.......did it start again after you left it for 5 minutes...
Donnie
Bilko, im afraid this will be one of those threads thats gonna get every reason under the sun, even the likes of Timbo can offer advice :shock: :shock: :mrgreen:
Donnie.
Donnie
As it is, its either fuel or electrical.
fuel?
Usual check you have some, then check breathers not blocked, then check chokes ok, then fuels getting to carb, then that carbs not flooding due to worn needle or stuck or punctured float.
At this point, DONT go farther on the fuel path.
Switch to electrical.
Electrical?
Unplug green from loom at CDI to eliminate kill switch / simple earthing, change spark plug for proper gapped one, change ht cap, ht lead and cdi
Still buggered?
NOW you need to think about either stator plates or cylinder / pistons.
But start simple and cheap first , ie plugs, cleaning carbs first....
Donnie.
Donnie
Oh and I'll change me bid to 40 Euro :lol: :lol: :lol:
Donnie.
