Welding on a scooter
Tractorman
- registered user
- Main scooter: Lambretta li150 special
- Contact:
Do I need to disconnect anything before doing any arc welding on a scooter. There is no battery on it and the fuel tank is off.
No,but if you are using stick or mig the spatter will get everywhere.Didn,t see you at ruskington tonight btw.
thebassmasta
- registered user
- Main scooter: GP TS1 240
- Contact:
yes ! disconnect your earths from your stator plate, or if you have a battery dissconect
Tractorman
- registered user
- Contact:
It was wet and it was a long way. I just have to tack a tail pipe bracket on then remove the exhaust and weld it up.roli-olo wrote:No,but if you are using stick or mig the spatter will get everywhere.Didn,t see you at ruskington tonight btw.
Tractorman
- registered user
- Contact:
Thanks for that, thebassmasta.thebassmasta wrote:yes ! disconnect your earths from your stator plate, or if you have a battery dissconect
thebassmasta
- registered user
- Contact:
no probs pal
Trojan
- registered user
- Main scooter: LAMBRETTA INNOCENTI
- Contact:
Thats right ,remove the earth wires from the casing to frame seeing as the rear shocker and engine mounts are separating the contact with the bushes, if I can advise, we normally weld at least three to four small tacks on a job save the pipe pulling over as its being welded, hope this helps.........
Tractorman
- registered user
- Contact:
Job done with the help of your good advise and everything still works, thanks
