Welding on a scooter
Tractorman
Do I need to disconnect anything before doing any arc welding on a scooter. There is no battery on it and the fuel tank is off.
roli-olo
No,but if you are using stick or mig the spatter will get everywhere.Didn,t see you at ruskington tonight btw.
thebassmasta
Main scooter: GP TS1 240
yes ! disconnect your earths from your stator plate, or if you have a battery dissconect
Tractorman
roli-olo wrote:No,but if you are using stick or mig the spatter will get everywhere.Didn,t see you at ruskington tonight btw.
It was wet and it was a long way. I just have to tack a tail pipe bracket on then remove the exhaust and weld it up.
Tractorman
thebassmasta wrote:yes ! disconnect your earths from your stator plate, or if you have a battery dissconect
Thanks for that, thebassmasta.
thebassmasta
no probs pal
Trojan
Main scooter: LAMBRETTA INNOCENTI
Thats right ,remove the earth wires from the casing to frame seeing as the rear shocker and engine mounts are separating the contact with the bushes, if I can advise, we normally weld at least three to four small tacks on a job save the pipe pulling over as its being welded, hope this helps......... 8-)
Tractorman
Job done with the help of your good advise and everything still works, thanks
