Chrome ring - headset gap
twin
your clamp will be bent down at the back,
victor
Main scooter: Tv175 but currently a SS210 :)
twin wrote:your clamp will be bent down at the back,
Will take it out and have a look. Should it sit flat say on a sheet of glass? Not having a correct one to compare with it'll be difficult to understand if it's bent, right?
victor
Picking up on this again since it's soon time to spray the scooter :)
Clamp is out but I cant see how the clamp could be bent, it's very robust and thick iron, has this ever happened to anyone else?
Or is it more likely the headset that is damaged...?
Thanks V
DigDug
victor wrote:Picking up on this again since it's soon time to spray the scooter :)
Thanks V
Get a new clamp £9.85 from SR..... - you can always sell it for £20 on Ebay if it's not that.
Did you have to do that?
victor
Yeah, would like to find out before spraying the headset though :D
DigDug
victor wrote:Yeah, would like to find out before spraying the headset though :D
If you order it now you'll have it tomorrow...
operonalan
Main scooter: tv200
I had same problem and yes it was the clamp that was bent ....hard to believe because it is thick cast etc but only became apparent when comparing it with spare clamp I had .
victor
It's really hard to believe as it's so thick, you'd imagine the aluminium would break first at an impact...
    Users browsing this forum: No registered users and 72 guests
