Oh, sorry, had me fooled, what is it then?DigDug wrote:As you can seethat is not a standard Innocenti disc brake on that bike.
DigDug wrote:The clue is the complete abscence of a brake cable.....
And therefore it isn't an original Lambretta disc brake is it?It's an original Innocenti disc brake hub with hydraulic conversion. Charlie used a modified EBC disc rotar and pads, as far as I remember from the Scootering write up on it.
And neither is one with reverse pull cable operation either: I'd hazard a guess that at least half of the original Innocenti disc brakes and copies that are in use are using either hydraulic or reverse-pull though. The question is, does the forced ram air effect cool the brake and improve efficiency? Some experts would seem to think that it does....DigDug wrote:And therefore it isn't an original Lambretta disc brake is it?
So it's an original, modified Innocenti disc brake, not one or the other?GP Kevo wrote:Sure it is, only the backplate is modified. Just because you don't believe it's an Innocenti brake that has a cooling scoop added to aid cooling doing exactly that doesn't change reality. I doubt anything on these race bikes is just for show.
