Disc brake air-scoop
Yanker
DigDug wrote:As you can seethat is not a standard Innocenti disc brake on that bike.
Oh, sorry, had me fooled, what is it then?
DigDug
The clue is the complete abscence of a brake cable..... :lol:
Did you have to do that?
Yanker
more a decoration for 'period authenticity' than a practical cooling aid then. :D
GP Kevo
DigDug wrote:The clue is the complete abscence of a brake cable..... :lol:
It's an original Innocenti disc brake hub with hydraulic conversion. Charlie used a modified EBC disc rotar and pads, as far as I remember from the Scootering write up on it.
DigDug
And therefore it isn't an original Lambretta disc brake is it? :?
GP Kevo
Sure it is, only the backplate is modified. Just because you don't believe it's an Innocenti brake that has a cooling scoop added to aid cooling doing exactly that doesn't change reality. I doubt anything on these race bikes is just for show.
Muppet
C’est la vie
Yanker
DigDug wrote:And therefore it isn't an original Lambretta disc brake is it? :?
And neither is one with reverse pull cable operation either: I'd hazard a guess that at least half of the original Innocenti disc brakes and copies that are in use are using either hydraulic or reverse-pull though. The question is, does the forced ram air effect cool the brake and improve efficiency? Some experts would seem to think that it does....
Wouldn't like to ride with the scoop in the snow though.....
DigDug
GP Kevo wrote:Sure it is, only the backplate is modified. Just because you don't believe it's an Innocenti brake that has a cooling scoop added to aid cooling doing exactly that doesn't change reality. I doubt anything on these race bikes is just for show.
So it's an original, modified Innocenti disc brake, not one or the other? ;)
... oh bloody hell .. to answer the orriginal question ... a scoop on a standard cable innocenti disc hub is purely ornamental
