RB20 dyno
ArKaTxU
shocky wrote:
RinB wrote:Not bad out the box
One thing I query is your gear ratio 4.8 yet only get 68Mph @8600
Doesn't calc out ??
PROB A 3RD GEAR RUN
8-) in 3rd its ok.
RinB
I believe it is a 3rd gear run just wanted to clarify :)
carlos fandango
drunkmunkey6969 wrote:What jetting are you running, and what was your Air/Fuel graph like? Did Readspeed discuss lean/rich spots with you or what jetting changes could be made? Top end power after the peak seems a bit rough, any further info?
Jetting tmx35
slide 6
57 needle top clip washer under
22.5 pilot
320 main
It is set up to run rich (safe), which i think is the reason for the bumpy peak?
Im not really interested in the figures (except for pub talk) I just wanted the carb set up, for piece of mind. :) the only difference from my set up was a 320 main for a 310 and a washer under the clip.
It still feel rich at quarter throtle.
my main concern after thinking afterwards was the flat spot at 5200 rpm, and what causes it?
A friend had his ts1 ( tmx35 & devtour) dynoed at diablos and he has the same flat spot.
So, is it the tmx, in particular the atomiser as this cant be change unlike the delly, or am i barking up the wrong tree.
This was my first dyno so had a lot to take in on the day, which is why i didnt ask Jerome :oops:
I know Jerome prefers dellys to mikunis ,as they are "easier to manipulate" on the dyno
Last edited by carlos fandango on Tue May 12, 2009 7:26 pm, edited 1 time in total.
Bufficus
carlos fandango wrote:
slide 4
I think that's why it feels rich at quarter throttle, the slide is possibly too rich.
A number 6 slide is used for most Lambretta applications.
I recently took the dremmel to a number 6 slide and removed more material on my TS1 too make it leaner at 1/4 throttle.
It was already on a 58 needle top clip, but was still too rich.:shock: I had nowhere else to go needle wise. I should add it is not a standard barrel.
carlos fandango
slide 4
:oops: My mistake it has a No. 6 slide not 4 :oops:
Bufficus
You could try a 58 needle and/or a smaller pilot if you're not happy with it. Perhaps it was set up rich for safety?
This chart is helpful.
http://members.value.com.au/jamesp/TMXneedles.doc
Chutney Brownlove
carlos fandango wrote: my main concern after thinking afterwards was the flat spot at 5200 rpm, and what causes it?
Don't all two strokes have a flat spot at around 5000rpm?
    Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
