What size is the hole the press in stud came out of?
Usually with metric, you can do thread size - pitch for the drill so drill 9mm, and you can use a first or second since it goes through and they're easier to get going, you only really need plug for blind holes.
Rear hub and SIP rims
- Toddy
- Main scooter: Lambretta Series 1
Good quality i ordered one on Ross's advice to clean my rear hub threads out after paintrosscla wrote: LH M10 x 1 off eBay for about a tenner from china, takes a week or two to come but does the job
make it easy on yourself and buy a uni hub from corrado it will be the safest option...drill and tap by all means and see how you go.. you could use it for a future build or...
- Toddy
Or a SIL one from scooter Rezzysdoggbhoy wrote:make it easy on yourself and buy a uni hub from corrado it will be the safest option...drill and tap by all means and see how you go.. you could use it for a future build or...
Doggbhoy
I think you may have a point.
Its probably worth buying one to negate any future problems.
Do you have a link to Corrado's shop?
Andy
Andy
1469leach
- Main scooter: jet200/rapido 225
I bought a new rear hub from rayspeed last year after the splines on my jet hub gave up,I think it was £34.95 and had threaded studs.They use them on there bikes and said they av no probs with them.
loanzo
I haven't even looked yet, but I think its the front too.
I have a disc on too, which provides me with another opportunity to bugger something else up
It's both that need longer studs. It's to do with the thickness of the wheel they have to make to give a well to have a chance of getting the tyre on and off
