5-speed-box
Mel K
Train Driver wrote:If you've worked out that it's not going to help then the only reason to have one is one-upmanship
or like me you like shiny new things :lol: :lol:
Oneupmanship? That could well possibly be just in the mind of the beholder.
In the mind of the on looker being the first to have the latest must have could be seen as something completely different :D But, as its all just a matter of opinion at the moment and opinions don't mean a thing only time will tell. :bigsm:
Dimitrios_231
Muttley McLadd wrote:
rbgaz wrote:what are u thoughts on the writeup in this months scootering ?
Can you scan and post it up?
You can try zinio.
It allows 3 zooms per issue.
Current issue http://gb.zinio.com/browse/publications ... =500604846
Previous month http://gb.zinio.com/browse/issues/index ... =416230068
Press the 'Inside' at the bottom of the magazine cover ;)
Dimitrios_231
Just read the article,
I want one NOW.
soosh
drunkmunkey6969 wrote:Yup, I know what you mean...I too owned a KR1. But then also, if I recall correctly the power was a claimed 60bhp, it redlined at about 12000rpm, had Kwak powervalves (KIPS?) and was reasonably aerodynamic....lol. The tune on those as standard was more than 'peaky'......without a close ratio box it would fall on its arse. Whereas most Lambrettas peak at about 6000-8000rpm, they have a broader 'enduro' type power band, and thier internals struggle to cope with more than 30bhp.
So like you say....it'll probably be the people that want one and can afford one that own them, more than any real 'need' for them?
They were good machines,loved mine but got it at a time i was a bit down,depressed!! Not a good idea.People go on about a quick Bretta and i used to too but this was totally different,the acceleration was just mental especially when the temp guage was reading half way....it was happy then.
tonydevon
Main scooter: '71 GP125
I suppose that the theory is good, ie you can keep it on the boil easier, the engine Im putting in my bike engined Lambretta build is 125 7speed, that was the same, great once up the revs and the valve opened, just keep shifting, revs drop by about 500rpm I think from memory, ideal for small buzzy high revving engines
but flippin hell thats a lot of money for a gearbox in a lambretta, especially if I read right and they only rated or tested to 25bhp, the serious people that might want to take use of the close ratio would be over that and are they then risking blowing a load of money :(
dirtyhandslopez
After years of spinning wrenches and hanging on to handlebars the old wrist are getting a little worn out nowadays. Much prefer an SX or TV box so's the gears don't have to be changed as often and tune/build accordingly
That's not going anywhere...
Yanker
soosh wrote:My chick gets a good bonus at Christmas so will have a word.
Will your taste buds be worn out by new year??
Fecking PMSL :lol:
Thing is we've all re-tuned our bretta kits to the 4 speed box. So it is not instantly attractive.
BUT if you look at the 'power-drop' graph in the article closely, you see how much of your (4 speed) tune is going to waste. Also you also see how any kit would work so much better on this gearing with out the need for the 're-tune' to developmore torque to overcome the gear/rpm band limitations. The scootering 'graph' is over complex as it is overlays two runs, it is also too small to analyse at first sight. It also uses an un-typical LI125 box on the standard example with short 1-2 gap long 3-4 ratios But if you spend 20mins 'unravelling' what it represents, then you see the gain, or better said 'lack of drops in power delivery': I bet it is a joy to ride.
I would not get all the benefit on my 250 Special from it either in it's current form, as I also re-tuned for a 4 speed box. Neither can I afford that price tag. Would not mind one though!
soosh
:D
Wee Mark
Main scooter: Lambretta TV200
Good luck to the maufacturer and those who backed it, but even the Mighty(& very Sucessfull) Tino Satchi had a go at doing this as well as others and never managed to get it right!!!....
Avantone
I really hope it's robust as it's the upgrade that gives everything and probably needs riding to fully appreciate.
The benefit from significantly increased overlap can't be underestimated.
It may be that some of the bigger capacity 30BHP+ motors can cope with a 4-speed box but for a standard or modestly tuned motor, this would have a real benefit.
This shows the comparison between the standard cyclone and an SX200 box - I know which one I'd rather ride.............
Tony
www.lambrettagearbox.com
    Users browsing this forum: Ahrefs [Bot] and 10 guests
