wont idle off clean.
idc1967iow
Hi i am running Muggy 186,delly 26phbh ,engine runs nice ,but when shutting down from a run it wont return to idle instantly ,takes a few moments to come down to idle ,could it be a weak slide,any idea's please???.
Thanks all
Ian. :fb:
Do you mean it runs high revs before settling ? If so it could be an air leak, check plug colour to ensure its not running lean, check all studs are tight and if your running rubber sleeve on your carb check for any splits..
Sent from my GT-I9000 using Tapatalk 2
idc1967iow
Checked all the joints all seem ok,plug light tan colour
idc1967iow wrote:Checked all the joints all seem ok,plug light tan colour
Milk chocolate light or milky bar light :-?
idc1967iow
Milk choc
Darrell Taylor
Main scooter: LAMBRETTA
try a bigger pilot jet up 1 or 2 sizes or start by adjusting the mixture screw setting it to a richer position the tickover will probably need turning up at same time ,check the carb isnt touching down onto anything causing vibration of the carb ,i presume its a rubber mounted carb
idc1967iow
Cheers for reply's,yes rubber mounted,will try the pilot jet :fb:
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1 guest
