Cooling fins??
Avantone
With all the purpose designed kits now being produced, I don't understand why the cylinders are all being shoe horned into a standard cowling.
With upwards of 100% more power and the associated heat being produced, wouldn't it make more sense to design a kit with a bigger surface area to dissipate the heat, and then market a specific cowling to go with it?
Almost like dropping a V8 in your Mini, and using the stock radiator!
Tony
www.lambrettagearbox.com
Bufficus
Interesting point. And some kit manufacturers are even reducing the fins on the barrels. :? :o
The RB 225 has only got 9.
Knowledge
It's a good point Tony. What are you thinking? Should the barrel fins be, say, 10mm wider all around the barrel?
Martin
Avantone
Knowledge wrote:It's a good point Tony. What are you thinking? Should the barrel fins be, say, 10mm wider all around the barrel?
It would make sense (to me) to have bigger fins on the exhaust side - there is plenty of space as opposed to the inlet side where there is little due to the frame tube.
Reading recently about the 60's AF250 with the motorcross cylinder made me think, as they had to machine down the fins to get it to fit inside the cowling - apparently it kept overheating!!!!!!
I was also thinking if header pipe itself could be modified with it's own headsink where it meets the cylinder to draw heat from the exhaust port.
Tony
jason frost
Or just redesign the cowlings to work better so they can be used on all kits
i mentioned before about the design of the fins on the flywheel possibly becoming useless at high rpm :?
those cowlings look cool though 8-)
jason frost wrote:Or just redesign the cowlings to work better so they can be used on all kits
very nice
are these available ?
can the cylinder cowling be removed with the engine in the frame without removing a "standard" [albeit 48mm] header pipe ?? cos removing the exhaust to check the head always annoys me
RBG
Come on Jason you cant post porno pic's & no details.
That's just cruel!
davidblythe
arent those MB's new turbo cowlings
RinB
davidblythe wrote:arent those MB's new turbo cowlings
Yep MB's Coming soon ;)
http://www.race-tour.co.uk/product.php? ... s/0007.jpg
