Has the drive side oil seal gone????
celt
Symptoms........
Smokey exhaust, oily plug, when covering/blocking exhaust at tickover dosen't cut out (JL exhaust badly leaking anyhow) rev's didn't increase when draining gearbox oil but oil was frothy and light green in colour :shock:
bristolmod
certainly sounds like it!
What does the exhaust smell like?
White smoke from exhaust?
Chris
Scootering since 1968.
celt
I haven't smelt the exhaust :?
Not white smoke but clouds of blue smoke.
I haven't put too much 2 stroke oil in mix either, before someone states this.
Gear box oil dosen't smell of petrol, but as I say light green in colour and frothy
bristolmod
generally if the D/S seal has gone, the smoke will be white and smell bleedin' awful.
Is the crankcase oil level dropping?
Chris
celt
bristolmod wrote:generally if the D/S seal has gone, the smoke will be white and smell bleedin' awful.
Chris
Not noticably, I usually put in 500ml. I drained it out into a seperate tub. When I get chance I will put this into old g/box oil bottle and see if if any has been lost
    Users browsing this forum: Semrush [Bot] and 12 guests
