series 1
simon k
Is it me or is there a blue Lego brick with ? On it ?
scooterslag
Sounds sweet- what motor you running chap? 8-)
The mack daddy on the left!
simon k
ha ha that may be my rear carrier/seat ricspeed!
engine is indian 200 barrel bored out to 69mm,2mm off the top,lth reed manifold,boost port,racetour piston with windows and skirt cut, exhaust & transfers lowered,widened & polished.58mm mec eur crank.matched & flowed casings,exhaust & inlet manifold.
30mm phbh & twin tailpipe 42mm clubman. re profiled head running without gasket.
top end work by jb.
Diablo
Looks and sounds lush
simon k
cheers Al. did you see the Nuneaton pit crew? ha ;)
cos i was veiwing on an i pod :oops:
lammysilver
haha, that woke half of the east end!... when me and Goz left after the 'launch' there were quite a few police around following a bit of gang warfare :ninja: on your doorstep... that exhaust has had a negative effect on your local community... Looked and sounded rapid though! Good work mate its almost ready for France!!!
Ian Hepworth
reminds me of when my mate Andy lived 2 doors away and he had a FS1E which had a pipe so noisy you could hear him about 2 minutes away.
Manos
The motor sounds great!!!
