Piston Ring Help
lammy mark
Main scooter: Series 3 Special s type rep.
I have bought a project 1963 Eibar Series 2. I have removed the head & barrel to give them the once over, but I managed to snap one of the piston rings. The rings appear to be 2.5mm in width. The piston head is marked 58.47..... is this the size of ring required ? Is this an over sized piston for a 150 ?
How do I measure the existing ring properly to get a match, or a new set ???
Cheers,
Mark
Scooterso
58.4 is a huge oversize. 57.0 is stock, and pistons go up in .2 increments. I have seen some suppliers selling up to 58.2 but not 58.4.
Can you get some calipers on the piston to check? Sometimes marks on the piston don't have anything to do with the actual size. Normally markings will be .2, .4 or like 1M, 2M..something like that...
lammy mark
Scooterso wrote:58.4 is a huge oversize. 57.0 is stock, and pistons go up in .2 increments. I have seen some suppliers selling up to 58.2 but not 58.4.
I will try and borrow a set of calipers and get a true measurement.
Cheers,
Mark
dapper
Why don't you get in touch with Bilko?? He's based in Belfast too and knows his stuff.
lammy mark
dapper wrote:Why don't you get in touch with Bilko?? He's based in Belfast too and knows his stuff.
58mm....cheers Bilko !!!
Bilko
Main scooter: LI150
ZOIKS! I don't know about that Dapper!
But I'll always help were I can.
Anytime Mark you know that mate.
Bilko's Oily Blog
