AMAL needle Clip
ROB
i have 3 amal mk1 needle clips....all are broken where you hang up the needle.
i thought its substandard parts but in this picure it looks a bit like it is broken as well. ???
maybe someone can help?
carlos fandango
Hi Rob
try these
http://www.auto-cycle.co.uk/
Regards
Russell
ROB
i found another one...of an old MK 1.5
as well with a crack....so i think it´s normal :?:
the amal MK1.5 have a round plate between the needle clip and the spring....that will spread a bit the pressure on the whole clip....so it´s no problem with the crack. and the needle cant slip out of the clip.
