i have 3 amal mk1 needle clips....all are broken where you hang up the needle.
i thought its substandard parts but in this picure it looks a bit like it is broken as well. ???
maybe someone can help?
AMAL needle Clip
- Attachments
- amalclip.jpg (5.54 KiB) Viewed 2682 times
- carlos fandango
- registered user
- Contact:
i found another one...of an old MK 1.5
as well with a crack....so i think it´s normal
the amal MK1.5 have a round plate between the needle clip and the spring....that will spread a bit the pressure on the whole clip....so it´s no problem with the crack. and the needle cant slip out of the clip.
