Cleaning cases
sydduckett
Need to clean my crank case up so it can be welded, so needs to be really clean/dry. Any suggestions of best stuff to get all the oil out? Aam leaving main bearing in so dont want anything that will f*** that up... :o
Ta
sef
jazzyb
just spent allday at waddos doing mine used traffic film remover then hot washed it of perfect 8-) 8-) 8-) 8-)
Always used gunk and elbow grease for years..what happened to your crankcase sef..?
Monty
Gunk then the dishwasher
J1MS
Vapour blast, then lightly scuff surface prior to welding to remove top layer of oxidised surface, wire brush with a stainless steel brush just prior to welding, and don't put greasy fingers back on the case after cleaning...
sydduckett
Lam, strange one really, hairline crack opened up running next to the engine numbers on top of the case. Its very fine but oil pisses out when it gets hot. Tried some aircraft grade liquid metal and it lasted about 2 weeks. No option now but to get it welded hence having to get it nice and clean. Ended up using gunk and the pressure washer :D
Thought while i was at it i would get all the things i either bodged or put off first time round done. Puting a 5 plate in, as the current 4 plate is slipping bad, weld shortened runners on and then re-spray the lot.......Was hoping to get it done in time for Holland at the end of the month, but that aint gonna happen... :(
sef
vegansydney
Yep, what J1MS said. Vapor/dry ice blasting. It will look like it has just rolled off the Innocenti factory line when finished. Cheap, non-abrasive and environmentally friendly too..does it get any better!
red ghost
Main scooter: lambretta gp150
vegansydney wrote:Yep, what J1MS said. Vapor/dry ice blasting. It will look like it has just rolled off the Innocenti factory line when finished. Cheap, non-abrasive and environmentally friendly too..does it get any better!
Well it could, we could have new cases rolling off the Innocenti factory line.
And that's not going to happen...or is it..... :smug:
sydduckett
No vapour blasting as the case is polished, but does sound the way to go for standard restos.. :o
sef
    Users browsing this forum: Baidu [Spider] and 30 guests
