italian 200cc engine
martin123
how can i determine what this engine is , its definitley a 200 italian engine, is there any way or number to check either a sx200 or gp200 or tv200 ?, the number has been completly filed off everything gone, came out of a tv175 s3 frame ,thanks
ArmandTanzarian
The real question is, "Why has the number been filed off?". None of the answers I can think of are very good news.
C*NTSPEED
ArmandTanzarian wrote:The real question is, "Why has the number been filed off?". None of the answers I can think of are very good news.
ditto
GEMINI S.C.
BLACK WIDDA'S S.C.
davidblythe
what is the internal engine case no, and post a pic of the top of the spigot
that will identify which case it is
sydduckett
That young man has been stolen at some point in the dim and distant past or some such criminal enterprise.... ;)
sydduckett wrote:That young man has been stolen at some point in the dim and distant past or some such criminal enterprise.... ;)
or filed off when the 125 law came in :oops:
martin123
i think it has had them taken off because on the v5 it is a tv175 series 3 but engine as a 125cc, so i think it was changed then sent off to have the engine changed on the log book, this was done a lot when the 125cc law came in, it has a 66.4 piston, a lug on the barrel with a 1 stamped in it also the inlet port stud spacings are wider as on the 200cc, it is a series 2 casing on it,
martin123
hi just been cleaning this engine casing up with a polishing mop to see if there are any numbers or letters left, and there is a letter T at the front so it is a tv200, now whats that worth, thanks
bristolmod
with a filed off number not as much as it should be!!
Scootering since 1968.
martin123
life is like that, not bad as the guy i bought it from thought it was a 125. now its up for sale.
