Crank Cleaning ??
whonatic
Following a melted honda piston showering my crank with aluminium......Whats the best way to clean it ?
monkey boy
I would remove the crank then clean it with petrol and compressed air
CHEERS AL
IF you get a realy sharp chisel..and I mean sharp you could remove the obstrution fairly easy matey as the ally wont deep key to the crank as the iron is much harder than the ally..
tony
Main scooter: 90ss
If it were me i'd get it split and checked. If that ally has run in that bearing it will damage it despite being softer.
