Series 2 hard to kick over
Grumpy225
I’ve had this happen on 3 builds now and not sure why.
viewtopic.php?f=7&t=40287&p=310831&hili ... rt#p310831
The most recent one is a Gori 200. I’ve lowered the compression to 120psi and it still fights me on starting. It feels like the kicker is getting hung up a little and just can’t push through to start it. After a couple of bumps on the kicker the motor will roll over like normal.
This only seems to be on Series 1-2 motors and I’m not sure if it’s a lever issue or what?
Never had this on any series 3 or gp motors, some with 150psi or more even.
MightyGem
I have a similar problem with my 150 series 2 that was given a stage 4 175 conversion. At times I have to my whole weight on the kickstart to get it to go down.
HxPaul
I have a Casa 185 on a series 1,too much compression,it seems like it wont kick up at times and I have to put all my weight (16 stones)on the kickstart.
Grumpy225
HxPaul wrote: ↑Sat Jun 20, 2020 8:04 am I have a Casa 185 on a series 1,too much compression,it seems like it wont kick up at times and I have to put all my weight (16 stones)on the kickstart.
MightyGem wrote: ↑Fri Jun 19, 2020 11:08 pm I have a similar problem with my 150 series 2 that was given a stage 4 175 conversion. At times I have to my whole weight on the kickstart to get it to go down.
This is what makes me think there is something else going on. Either a case cover issue like worn bushings or a chain alignment issue? I'm wondering if anyone has specifically run across this and found a fix? I have't found anything in Sticky's or online forums on this other than the link above.
hendy
It's not just about compression ratio. As already pointed out, it's the lever, or rather the ratio of engine revolutions versus distance of lever travel.
I've done a couple of builds like this recently and used a bigger front sprocket to resolve it. On LI150 with scootopia kits, a 16 tooth sprocket was enough to sort it out.
Grumpy225
hendy wrote: ↑Mon Jun 22, 2020 7:47 am It's not just about compression ratio. As already pointed out, it's the lever, or rather the ratio of engine revolutions versus distance of lever travel.
it's got a 17/46 on a LI125 gear box and that did help a little
Norrie Bodge
Grumpy225 wrote: ↑Tue Jun 09, 2020 6:50 pm I’ve had this happen on 3 builds now and not sure why.
https://www.ebay.co.uk/itm/LAMBRETTA-KI ... XQ3kRQ8dLi
HxPaul
The kickstart pedal on series 1 and 2 is considerably shorter than a series 3,I think that has a lot to do with it.
EddieStone
The kickstart tab isn't fouling on the exhaust pipe, is it?
Grumpy225
Norrie Bodge wrote: ↑Tue Jun 23, 2020 10:31 pm
That might be the end solution but for now it’s got a s2 cover on it. Maybe I’ll save that for when the cover breaks? Thanks for the link
