wiring problem?
Hooner
Main scooter: lambretta gp
gp scoot won't start unless brown and green wires in headlamp j/box are connected together, Any ideas whats wrong,cheers.
It depends how its Wired and where the Brown abd Green come from really , The Green is usually an Ignition / Kill feed and Brown is Lights /Power feed unusual they are both together unless somewone has wired different ?
Daggs
Green is usually reserved for the ignition. Therefore should never come in contact with any other circuit.
It would seem whoever wired this machine has not followed that convention.
Is it 6V original/6V electronic/12V electronic conversion?
Hooner
it's 6volt points with 12volt headlight bulb.
mick1
Main scooter: Li Avanti 225
Why is it an issue ? does everything work ?
firekdp
If it won't start without the brown and green connected together, I would suspect you have low, or no power coming from the stator ignition coil. Check the condition and connections on this, especially the earth one.
Meds1
Main scooter: Lambretta li150s
Have a look on Facebook for lambretta electrics, that might help you understand how the circuits work-
Hooner
mick1 wrote: ↑Wed Nov 27, 2019 10:38 pm Why is it an issue ? does everything work ?
yes everything is working now, but it wont start unless green and brown are connected, brown is for the horn, red, brake light, violet for the lights,and green for the coil. So does it seem there is a problem with the starter winding in the stator? thanks for the replies guys.
