Found a phbl sized foam filter for restricted room
Davidsquaredson
It's for a Briggs and Stratton lawn mower. I have no idea if you can get in the UK, I got it for 20$ on Amazon. Fits snug over the 39mm opening and perfectly under the panel. I did not have to adjust my jetting to my great surprise.
Part # on package.
DDImageImage
Sent from my Pixel 2 using Tapatalk
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
paul d
Main scooter: T5 172 Tv 240
Great post. Most towns here have someone who fixes lawnmowers. It could be a handy fix for anyone on the road who's lost an airfilter.
gaz_powell
Pattern versions not genuine B&S £2.50 on ebay!!!
gaz_powell
Found them for 99p! Worth a punt
Guessing it might be flexible enough to fit on a PHBH too if need be?
gaz_powell
35mm dia hole in the filter
YAMLAM
the cheap one i bought on ebay has a 40mm hole :(
win or lose have a booze
That wouldn't be too much is a stretch on the phbh which is 42 mm without the plastic bellmouth
Warkton Tornado No.1
Main scooter: Lambretta SX200
Any feedback on these filters from those that were going to get one to try?
Do they work well enough to be non restrictive?
Any issues with hot starting (due to flooding) from fans of the PH range?
YAMLAM
Had to cut the corner away a bit on mine ,where the fuel bango /pipe is , i know the hole is slightly larger than my PHBL 25 but stays in place against the panel, doesnt affect the running at all.
be switching to a Mikuni TM24 soon , hopefully it will still fit .
    Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 19 guests
