Lambretta Speedo Light Always On
NEW MEMBER? - You must now introduce yourself here first BEFORE you can post in any other section!
Say hello and let us know a bit about you and what scooter you own, etc...THEN you will be able to post elsewhere.
Northener
Main scooter: Lambretta SX200
I've an Italian GP150 totally standard 6v AC (non-battery), when i kick this up & it is only on ignition (first right turn) the speedo light is on, it wasn't before but is now, can only assume some wires maybe touching after working on it.
Anyone who's more electrically minded got any ideas?
Thanks.
Welcome aboard.
Sounds like your black speedo bulb wire is connected directly to the wire bringing power up you your headset junction box - probably a brown but maybe purple.
The speedo light should be connected to the black from the switch and the one that goes to the tail lamp.
Northener
It was what you said 'rosscla' so thanks for your help everything sorted now!
Good work
welcome to the forum, glad you are getting stuck in and getting good advice straight off the bat! ;)
    Users browsing this forum: No registered users and 45 guests
