Sprint Rack Rubbers ??
nellyboyo
Anyone got any idea where to get the rubber spacers that sit between the rack and the frame ? Or any other things that will fit ?
I've got a couple of O-rings on each at the moment ..someone must have a better idea ? cheers
garry inglis
Just use some off the floor rubber washers that you use on a lambretta to stop the floor vibration
Timbo
Any motorist shop will sell rubber/plastic washers.....
Meds
Main scooter: Li125s
I use big rubber tap washers
Mrnice71
Main scooter: Lambretta series 3
I found some small white doorstop rubbers from a hardware store & cheap
nellyboyo
Ha doorstop washers will be the one !!
If you use normal rubbers etc then the rack sits too close to the frame . The old perished ones had half inch inside the recess where the rack sat against and couldn't be tightened down any further . This then held the rack away from the frame so you could get your fingers under it for bungees etc .
I don`t know if I explained that very well :D
    Users browsing this forum: No registered users and 34 guests
