Anyone got any idea where to get the rubber spacers that sit between the rack and the frame ? Or any other things that will fit ?
I've got a couple of O-rings on each at the moment ..someone must have a better idea ? cheers
Sprint Rack Rubbers ??
- garry inglis
- Main scooter: ts1 230 and rb200
Just use some off the floor rubber washers that you use on a lambretta to stop the floor vibration
I use big rubber tap washers
nellyboyo
- Main scooter: Lambretta
Ha doorstop washers will be the one !!
If you use normal rubbers etc then the rack sits too close to the frame . The old perished ones had half inch inside the recess where the rack sat against and couldn't be tightened down any further . This then held the rack away from the frame so you could get your fingers under it for bungees etc .
I don`t know if I explained that very well
