Vespa GTV - Sei Giorni - Ltd Edition
The print magazine news, reviews, latest products, events & more....
:ugeek: :ugeek: :ugeek:
Thoughts on this? Fabulous modern update, or desecration of a classic?
Personally, I love it...but then, as you might have guessed, I do embrace change! :lol:
More info to follow in Scootering... 8-)
TECH SPEC:
Type: Single-cylinder, 4-stroke, 4 valves, electronic injection
Engine capacity: 278 cc
Bore x Stroke: 75 mm x 63 mm
Max power at crankshaft: 15.6 kW (21.2 HP) at 7,750 rpm
Max Torque: 22 Nm at 5,000 rpm
Fuel system: P.I. Injection (Port Injected)
Ignition: Electronic, with variable advance
Cooling system: Liquid Lubrication:
Wet sump Gearbox: CVT with torque server Clutch: Automatic centrifugal dry clutch
Chassis: Sheet metal body with welded reinforcements
Front suspension: Single arm fork with coil spring and hydraulic control
Rear suspension: Double hydraulic shock absorber with four-position spring pre-load adjustment
Front brake: Hydraulically operated 220 mm stainless steel disc - ABS
Rear brake: Hydraulically operated 220 mm stainless steel disc - ABS
Front tyre: Tubeless 120/70 - 12"
Rear tyre: Tubeless 130/70 - 12"
DIMENSIONS
Length/Width: 1950/770 mm
Wheelbase: 1375 mm
Saddle height: 790 mm
Fuel tank capacity: 8.5 litres
Emissions compliance: Euro 4
Bofs
Same here, love it!!
Sent from my D5803 using Tapatalk
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
Gage
Main scooter: TV200, P2, VB1+Bambini, GTV300
Just ordered mine. Interest free over 5 years, £84 per month, can't be bad. This is my third brand new Vespa and I have just realised that I seem to get a 15 year itch, purchase dates are all in September, 1987, 2002, and 2017, spooky. Looks like 2032 will be the next one.. High performance Electric GS150 maybe........ (in case you are reading Piaggio)..
    Users browsing this forum: No registered users and 59 guests
