Thoughts on this? Fabulous modern update, or desecration of a classic?
Personally, I love it...but then, as you might have guessed, I do embrace change!
More info to follow in Scootering...
Vespa GTV - Sei Giorni - Ltd Edition
TECH SPEC:
Type: Single-cylinder, 4-stroke, 4 valves, electronic injection
Engine capacity: 278 cc
Bore x Stroke: 75 mm x 63 mm
Max power at crankshaft: 15.6 kW (21.2 HP) at 7,750 rpm
Max Torque: 22 Nm at 5,000 rpm
Fuel system: P.I. Injection (Port Injected)
Ignition: Electronic, with variable advance
Cooling system: Liquid Lubrication:
Wet sump Gearbox: CVT with torque server Clutch: Automatic centrifugal dry clutch
Chassis: Sheet metal body with welded reinforcements
Front suspension: Single arm fork with coil spring and hydraulic control
Rear suspension: Double hydraulic shock absorber with four-position spring pre-load adjustment
Front brake: Hydraulically operated 220 mm stainless steel disc - ABS
Rear brake: Hydraulically operated 220 mm stainless steel disc - ABS
Front tyre: Tubeless 120/70 - 12"
Rear tyre: Tubeless 130/70 - 12"
DIMENSIONS
Length/Width: 1950/770 mm
Wheelbase: 1375 mm
Saddle height: 790 mm
Fuel tank capacity: 8.5 litres
Emissions compliance: Euro 4
