Wont idle!
Suede Ed
Main scooter: SIL GP200
Casa 185 fitted with a 25mm phbl (straight out of the box) through a drilled airbox. Pipe is AF clubman. Starts fine, runs ok, but will only tick over fast with a little pressure on the throttle. Idle screw seems to have no effect??
holty
Main scooter: lambretta gp
have you checked that the choke is in the off position, and the plunger is all the way down with a little bit of free play on the cable ?
camel
Sometimes the spring becomes coilbound on dellorto,s preventing you winding it in enough to raise the slide,worth a look,if so just shorten the spring a tad
camel
On the tickover screw i should add
