TS1 port timings timings - anywhere near?
alanscottj
Just had a go at measuring my port timings for the first time. Stage 2 Road/Race tuned TS1 will be using a Franspeed Race.
Here's what I got:
Exhaust 172
Transfer 130
This is with a 110 x 60 crank with 3mm packer.
Would really appreciate any thoughts on if these are ok and I can get on with rebuilding her :D
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox πŸ˜ŽπŸ‘
hendy
Sounds very low on the exhaust to me. I Think standard ts1 exhaust is around 188.
My guess is that you've measured your exhaust upside down or inside out. In other words you've measured how long it's closed rather than open.
Muppet
degrees disc
C’est la vie
alanscottj
hendy wrote:Sounds very low on the exhaust to me. I Think standard ts1 exhaust is around 188.
Just measured again and got exactly the same. You say a standard is 188, would mine being tuned not make it different?
hendy
Probably would change but would generally increase unless they've added a steel liner. Even with a steel liner 172 would be surprisingly low to me anyway.
alanscottj
hendy wrote:Probably would change but would generally increase unless they've added a steel liner. Even with a steel liner 172 would be surprisingly low to me anyway.
Okey dokey, I'll take it with me tomorrow when I go to local scooter shop for some bits. See if they will have a look, no idea if I'm doing it right :roll:
alanscottj
Watched the video again! And re-measured - this time I got 190 - exactly what MB thought it would be :D
Need to recheck my transfers now ;)
alanscottj
Re-cked my transfers and I was right with them, as you said Hendy, I was measuring the exhaust from the outside, looking through the exhaust manifold :roll:
So, timings now, confirmed are:
Exhaust 190
Transfers 130
Which gives me a blowdown of 30
Tried new CNC head and it looks like I will need a head gasket of 2.5mm to get 1.3 clearance.
How do these figures sound???
    Users browsing this forum: No registered users and 70 guests
