Here's what I got:
Exhaust 172
Transfer 130
This is with a 110 x 60 crank with 3mm packer.
Would really appreciate any thoughts on if these are ok and I can get on with rebuilding her
Just measured again and got exactly the same. You say a standard is 188, would mine being tuned not make it different?hendy wrote:Sounds very low on the exhaust to me. I Think standard ts1 exhaust is around 188.
My guess is that you've measured your exhaust upside down or inside out. In other words you've measured how long it's closed rather than open.
Okey dokey, I'll take it with me tomorrow when I go to local scooter shop for some bits. See if they will have a look, no idea if I'm doing it righthendy wrote:Probably would change but would generally increase unless they've added a steel liner. Even with a steel liner 172 would be surprisingly low to me anyway.
