Flywheel Woodruff Key
Fruitjuice
Is a Lambretta Flywheel Woodruff Key the same as a Vespa Flywheel Woodruff Key?
Fruitjuice
I just found out it's the same as a vespa Clutch Woodruff key. (4mm wide x 6,5mm high x 15mm long)
