Flywheel Woodruff Key
Fruitjuice
Is a Lambretta Flywheel Woodruff Key the same as a Vespa Flywheel Woodruff Key?
Life shouldn't be a journey to the grave with the intention of arriving safely in a pretty, well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, loudly proclaiming: "WOW, WHAT A RIDE"
Fruitjuice
I just found out it's the same as a vespa Clutch Woodruff key. (4mm wide x 6,5mm high x 15mm long)
