Higher than normal tick over
alanscottj
Evening!
Just been for a spin on the scoot and noticed that it is idling much higher than usual - about 3000 rpm - constant, not increasing. Adjusting the idle screw is having not impact whatsoever - could it be an air leak or something else?
Scott
TS1 - TMX - Franspeed Super - Varitronic
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox πŸ˜ŽπŸ‘
Knowledge
It could be an air leak.
Martin
alanscottj
Yeah, that's what I'm thinking - I have a leak down tester so will have a test over the weekend to rule it out. As I will have to take the pipe off it'll be a good chance to swap the front sprocket :lol:
alanscottj
Found it! Just had a closer look at the carb to check the slide wasn't sticking and tried to twist it to check it was still on tight and the rubber split! It's only been on a couple of months :roll:
Ok- next question - Who does the best carb rubber for the TMX35 ???
alanscottj wrote:Found it! Just had a closer look at the carb to check the slide wasn't sticking and tried to twist it to check it was still on tight and the rubber split! It's only been on a couple of months :roll:
What type you got on now ? I use the MB ones on my tmx for the last year been fine
alanscottj
What type you got on now ? I use the MB ones on my tmx for the last year been fine[/quote]
Will check tomorrow - Chiselspeed put it on a couple of months ago when I had her dyno'd there.
alanscottj wrote:What type you got on now ? I use the MB ones on my tmx for the last year been fine
Will check tomorrow - Chiselspeed put it on a couple of months ago when I had her dyno'd there.[/quote]
Are you sure nothing's pushing the carb putting stress on the rubber or the jubilee clip has cut it ?
alanscottj
Are you sure nothing's pushing the carb putting stress on the rubber or the jubilee clip has cut it ?[/quote]
I have a feeling the jubilee clip cut it - it was on very tight.
