Halogen light conversion - can I use this?
alanscottj
Bought this a while back. Fancy fitting it this weekend to my GP but I seem to remember reading somewhere that I can't use it with a SIP speedo. Scooter hasn't got a battery just a Varitronic ignition. Will it work? Any thoughts? Cheers.
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox πŸ˜ŽπŸ‘
i have that and a SIP speedo, no problems running both.
alanscottj
22/2 wrote:i have that and a SIP speedo, no problems running both.
And the Varitronic ignition should be ok I presume?
holty
Main scooter: lambretta gp
The ignition coil is not the coils that the lights use, So it won't affect your variatronic ignition, I have one of these in both my gps and they work fine, actually it looks like the ones I sell, they give a very good headlight, I've got a battery on one and ac on the other, both have a very bright light, mine don't have the sip speedo though, an led rear light is an advantage as it will give more power to the headlamp
Holty
alanscottj
Thanks all - fitted yesterday and works spot on. The only problem is that the rear brake light isn't getting much juice now. It is very dim :roll:
holty
either a led bulb, which isnt very good, better with one of these, i make them myself.
alanscottj
holty wrote:either a led bulb, which isnt very good, better with one of these, i make them myself.
How much for one of yours please?
holty
pm sent
alanscottj
holty wrote:pm sent
Received in post today mate, thank you very much. Should get it fitted over the weekend :D Looks a great bit of kit
holty
alanscottj wrote:
holty wrote:pm sent
your welcome, any problems let me know,
holty
